Removing Climate Control Panel
Old Feb 26, 2007 | 01:29 AM
ltkenbo's Avatar
Default Removing Climate Control Panel
I was wondering how to remove the panel above the center console with the radio, and climate controls. Some people said something about a screw under the hazard light switch but I didn't see one. I have a '99 sedan.
Old Feb 26, 2007 | 09:29 AM
Default RE: Removing Climate Control Panel
You gotta remove the sectoin with the lighter in it, which requires you to remove the belly pan under the steering wheel as well as the same section on the passenger side. Once that middle bottom portion is out, you can look up and you'll see four screws holding it in place
new_2_civics
Apr 1, 2010 02:37 AM
tgs
Mar 28, 2010 07:12 PM
jaymacf3
May 24, 2006 03:32 PM
WillVTEC
Oct 5, 2005 07:46 PM
PredatorCoder
Aug 15, 2005 05:43 PM
