Replacing Bearings
Old Jun 10, 2008 | 09:22 PM
sLyda's Avatar
Default Replacing Bearings
Is Their A Thread Or Tutoral On How To Replace Bearings On A 2000 Civic Ex?
Old Jun 10, 2008 | 09:33 PM
Default RE: Replacing Bearings
I don't believe so. Removing and installing wheel bearings require a press, which most people don't have. But you can still do most of the work yourself by removing the wheel hub. See the service manual for details. Then take the hub to a shop that will install the new bearing for you.
Old Jun 10, 2008 | 09:41 PM
sLyda's Avatar
ohh arrite, another question, how can u tell that your bearings are gone?
Old Jun 11, 2008 | 04:42 AM
Excess free play in a wheel is one sign. But commonly a bad wheel bearing will become noisy, producing a humming noise that intensifies as your speed increases.
Old Jun 11, 2008 | 01:47 PM
SilverSedan's Avatar
The noise will also change if you weave slightly side to side.Passenger side went on my 97 2 summers ago. I got it up to about 45mph on a clear highway and just did some slight weaving side to side. as the weight transfers side to side the noise will fade in and out if its a wheel bearing. For example, mine would get QUIETER as I turned right (weight transfers to the left and off the wheel bearing) and then get louder again as I would turn left (which of course transfers more weight back onto it)
thakid
Dec 14, 2011 01:48 PM
PirateX
May 24, 2008 09:14 AM
vdog
Nov 21, 2005 12:20 PM
thebrodizzle
Jun 7, 2005 06:27 PM
Remmy
33
Apr 1, 2005 11:32 AM
