Rough running
Let's see if anyone has any suggestions. I have a 91 crx with an LS swap and when I start my car it will run fine for a few minutes then sometimes run real rough then almost die, then it will rev up a couple hundred on it's own and be fine until the next day. It will also run rough while driving sometime during the first 10 minutes or so of drivng then be fine. Any ideas will be much appreciated.
Do all your rough running problems happen at idle? If i had to take a guess i would say either a MAP sensor, temp sensor, or IACV is not workign correclty. If you have access to a scan tool that will display live data, check all the sensors and make sure everything is fine (i.e. the engine temp isn't like -20 F)
Stumasters
Jan 20, 2008 12:58 PM
camarogirl2683
Jul 25, 2007 12:12 PM
Scott99
Sep 15, 2005 02:32 PM
kjreinha
Feb 4, 2005 01:58 PM
