shifter
sorry for all these questions guys seems like i'm takin advantage but i just bought this civic and little problems i need cleared heh. ok so i have this rattling problem in 3rd and sometimes 5th gear. seems like the shifter itself is rattling inside the shift ****, i can feel it hittin the walls of the shift ****, what would cause this? bad ****, shift linkage?
chances are, your shiftknob is loose on the shifter. If thats not it and it seems further down than that, check the shift linkage where your shifter joins up. Worst case scenario grab a short-shifter kit and see if that worse. Maybe your rpms are too low when you shift into 3rd/5th?? I know its a stupid suggestion but im not sure how familiar you are with cars. Kinda like someone who knows nothing bout computers: if it wont turn on check the power cord.
Also, dont worry about asking questions. Its what the forums on the interweb are for.
I had a similar prob and it was that torque bar that runs from the shifter to a mounting point on the tranny. runs right along side the actual shift linkage. Had a worn rubber bushing so I wrapped it in electrical tape and forced it back it. Good as new!
Check the **** first tho its prolly that.
checked the **** hand tightened it as much as i could, thought i fixed it but came back, seems to be right inside the **** like its hitting the walls where it screws in, possibility bad **** or should i investigate further down to bushings?
So it sounds to me like the shift **** is loose and/or doesnt fit the shifter correctly. If it feels like the shifter is loose and hitting the inside of the ****, then its your ****. Either it doesnt fit or its all screwed up. Is it the stock one?
it should get to a point where you can't turn it anymore, as you'll bottom out the threads on the ****/shifter
if it never stops turning, perhaps the threaded insert has come loose from the **** itself?
addiction2bass
Mar 28, 2010 11:34 AM
Mr^Man
Transmission and Differential
Oct 19, 2008 04:21 PM
addiction2bass
Dec 25, 2007 10:46 AM
dalifts
Sep 21, 2004 12:22 AM
