Shifter Jumpping out of Gear
Old Sep 20, 2005 | 01:12 PM
vdog's Avatar
Default Shifter Jumpping out of Gear
When I take off, when I go into 2nd gear, sometimes it does not go into gear, or it will jump out of gear. Or I have to force it into gear.
Is this a shift linkage problem, or a transmission problem?
Thanks
Old Sep 21, 2005 | 01:08 PM
jake11375's Avatar
Default RE: Shifter Jumpping out of Gear
That sounds like your synchros in your transmission for 2nd gear. Does it do it in every gear or just #2? Either way, if it is your synchros, you'd be better off replacing the whole tranny rather than just one gear. If some are bad then more than likely, the rest of them are well on their way.
Old Sep 21, 2005 | 01:20 PM
its probly that damn homemade intake causing the problem
just playin' bro, but yeah it does sound like your synchros.
Old Sep 21, 2005 | 01:39 PM
vdog's Avatar
Your right, it could be that darn intake! LOL
So transmission instead of shifter bushing? Because my shifter is very loose, and the rubber bushing under the car is worn out.
Old Sep 21, 2005 | 03:34 PM
z6 FoRiLLa's Avatar
only going into second gear?
Old Sep 21, 2005 | 05:27 PM
vdog's Avatar
If im crusing in second, say in a parking lot, or if im just driving like my car is fast, (LOL), it will jump out of gear into neutral. Im still on the gas not knowing until the engine is reving up and the motor is racing. But yes just second gear.
Old Sep 22, 2005 | 03:56 PM
jake11375's Avatar
Then it is your synchro in 2nd gear. This comes from high redline shifts into a particular gear, gear grinding, or simply a lot of wear. The faster the tranny and gears spin, the more accurate shifts must be to ensure proper change and transmission life. If not, the synchronizing mechanism and gears become damaged. The thing about replacing one sychro is you have to take the entire transmission apart to get to that gear. This will probably cost more than just putting a new tranny in. You should be able to get a manual tranny installed for $400-$600. Automatics are much pricier. Have a mechanic check it out... Good luck!
Old Sep 26, 2005 | 11:18 AM
vdog's Avatar
Thanks I will start looking for a transmission now. Great more money to spend.
Old Oct 4, 2005 | 01:39 PM
Sik 6's Avatar
I know on motorcycles that symptom would lead to a bent shift detent, If car trans are like m/c trans i would bet on that.
andybuck711
Mar 3, 2010 07:14 PM
honda_dud
Jul 10, 2009 06:48 PM
chasemclemore
May 18, 2009 04:21 PM
Mr^Man
Transmission and Differential
Oct 19, 2008 04:21 PM
addiction2bass
Dec 25, 2007 10:46 AM
