Short grinding sound after ignition
Old Nov 23, 2007 | 10:59 AM
rizzleton's Avatar
Default Short grinding sound after ignition
'02 Civic Si
When I start the engine, I hear a grinding sound for about half a second just after/during ignition.
It sounds like gears in the transmission grinding but I've got the clutch all the way in and the car is in neutral.
It doesn't make this sound while I'm driving or when I turn off the car. Only when I start it.
Old Nov 23, 2007 | 11:06 AM
Hailchristian's Avatar
Default RE: Short grinding sound after ignition
after the car starts are you still turning the key?
cause if your car starts and you turn the key it it will grind your starter against the flywheel...that might be the sound you are hearing.
Old Nov 23, 2007 | 12:04 PM
Mugan's Avatar
Clean or replace your starter. When you have the starter off turn the engine and check your flywheel for damage/warp.
NIKE H34D
12
Mar 26, 2009 12:13 AM
Kaled
Jun 14, 2008 04:05 PM
cinefyl
May 21, 2006 12:54 PM
rit14623
Mar 7, 2006 08:24 AM
red_sleeper
Feb 12, 2005 11:49 PM
