Solved Problems (Check Here First)
Old May 15, 2011 | 07:55 AM
  #31
VRO's Avatar
VRO
What's up with all the links not working? Something I'm supposed to do other than clicking on them?
Old May 28, 2011 | 05:46 PM
  #32
TitaniumLaoZ's Avatar
I have a 94 civic ex at. It cranks n I can turn my lights on bt it won't start. please email me at laosfullback@yahoo.com
Old Jun 22, 2011 | 10:48 AM
  #33
Oozmiester's Avatar
Default Links
I can't seem to get the below links to work, are these correct ?
Trying to get this one up but it says page does not exsist.
1. Cranks but won't start: https://www.hondacivicforum.com/m_97980/tm.htm
Thanks
Scott
Originally Posted by XCM828
This is a list of various problems people have had solved by HCF users. Before you post, skim these lists because somebody might have already fixed your problem. If you have had a problem solved in any of the forums, please PM me and I will add them to the list. Enjoy!
General
2. Intermittent starting and stalling problems: https://www.hondacivicforum.com/m_82668/tm.htm
Cooling, Heating, and A/C
1. Water temp. needle moving up and down: https://www.hondacivicforum.com/m_91868/tm.htm
2. A/C smell: https://www.hondacivicforum.com/m_92756/tm.htm
3. Overheating problems: https://www.hondacivicforum.com/m_82002/tm.htm
4. A/C vent rattle: https://www.hondacivicforum.com/m_79630/tm.htm
Fuel and Exhaust
1. Car bogs during acceleration: https://www.hondacivicforum.com/m_96852/tm.htm
Engine Electrical
1. Replacing distributor: https://www.hondacivicforum.com/m_98965/tm.htm
2. Car starting problems: https://www.hondacivicforum.com/m_81093/tm.htm
3. No spark: https://www.hondacivicforum.com/m_82923/tm.htm
4. Car bogs in lower RPM band: https://www.hondacivicforum.com/m_133369/tm.htm
Transmission
Clutch and Driveline
1. Grinding noise in axle bearings: https://www.hondacivicforum.com/m_94069/tm.htm
Brakes
1. E-brake light flickering: https://www.hondacivicforum.com/m_97413/tm.htm
2. Brake noise (with sounds clips): https://www.hondacivicforum.com/m_89552/tm.htm
3. Rotor screws: HondaCivicForum.com - Powered by vBulletin
Suspension and Steering
Body
1. Removing bumper cover: https://www.hondacivicforum.com/m_98838/tm.htm
2. Trunk lever not opening trunk: https://www.hondacivicforum.com/m_96511/tm.htm
3. Water under driver's left foot: https://www.hondacivicforum.com/m_66590/tm.htm
4. Water under passenger seat: https://www.hondacivicforum.com/m_58633/tm.htm
Chassis Electrical
1. Resetting SRS light: https://www.hondacivicforum.com/m_99522/tm.htm
2. Aiming headlights: https://www.hondacivicforum.com/m_94836/tm.htm
3. Window rolls up slowly: https://www.hondacivicforum.com/m_79971/tm.htm
4. Stereo not working after power disconnected: https://www.hondacivicforum.com/m_89985/tm.htm
5. Window comes off of track: https://www.hondacivicforum.com/m_124507/tm.htm
Random
1. Door froze shut: https://www.hondacivicforum.com/m_134084/tm.htm
Old Jul 6, 2011 | 12:56 PM
  #34
joe455's Avatar
Default Most of these links are saying page not found, does anybody know what the deal is?
Thanks
Scott
I am having issues finding what I need as well. Most of the pages when clicked on say page not found.
I am having issues with my crankshaft positioning sensor on my 03 civiv 1.7. Had my timing belt and water pump changed 2 months ago and it started surging a month later. Took it to a mechanic near me and he said my water pump leaked on the sensor and ruined the sensor. So I took it back to the original shop to do warranty work and he said the sensor was fine after he cleaned it with a sensor cleaner. It drove fine at first but lately has been surging just a little. Has anyone else had this happen?
Old Jul 19, 2011 | 06:33 PM
  #35
92CivEx's Avatar
None of the links are working! What happened?
Old Jul 19, 2011 | 07:01 PM
  #36
Well, darn.
The forum software has been updated twice since this thread was started. It appears that the links are all dead and this sticky is no longer useful...
Y_dolan
Sep 10, 2013 11:58 AM
DaRKoN
May 6, 2008 07:12 PM
windcalmer
Sep 3, 2007 01:06 PM
dalifts
Nov 13, 2004 09:58 PM
