sony deck installation in 02 civic LX
Old Jan 4, 2012 | 01:49 PM
D.webster01's Avatar
Default sony deck installation in 02 civic LX
alright i have installed a sony deck and it won't turn on. this is the second one.
i have connected each of the wires according to their color and before connecting the yellow and red wires i connected the ground first
the fuse in the deck is fine and so is the one in the fuse box in the car
i have checked the wires for power using a voltage meter and they seem to be working fine with one providing 12 volts.
what am i doing wrong? what is causing the deck not to turn on?
Old Jan 4, 2012 | 02:21 PM
Power for the yellow wire comes from a fuse under the hood. Both the yellow and red wires must have 12 volts with the key on, with the key off, the red wire turns off but the yellow one stays live. If you have power on the yellow and the red wires, and the black is ground, and the deck won't come on, check for shorts in the speaker wires-- either to each other or to ground. Some decks will shut down completely when they detect a problem with the speaker circuits. Finally, remove the unit and power up the yellow red and black wires ONLY from a battery on a bench, leave all other wires disconnected. If it still won't come on, it must be defective.
theRDRman
Dec 31, 2010 05:03 PM
ziggieboi
Jan 25, 2007 12:35 PM
hardunaware
Apr 2, 2005 01:44 PM
ballplaya4eva07
Mar 29, 2005 02:58 AM
