Sqeaky Clutch
Old Aug 17, 2006 | 03:56 AM
Default RE: Sqeaky Clutch
ORIGINAL: deserthonda
chk to see if it also makes the noise while casr is shut off,,,,,
if it does , the pivot ball on the tranny where the clutch fork pivots is dry, it need to be lubed..pull back on the rubber boot by the slave cylinder, get a can of wd-40 or spray grease . spray the area inside the tranny wherre the fork is at .. have someone depress the clutch pedal while you do it ...
if the noise is when engine is running and clutch is deprerssed ,, most likely ,, it is the clutch bearing
thats what my 92 hatch was doing great advice deserthonda are you on haf
Old Aug 18, 2006 | 12:04 AM
deserthonda's Avatar
ORIGINAL: Peg_Leg
[/quote]
yep i am at HAF full time ,, I am 1 of the Moderators there,, i come here from time to time when i am done over there,, figure someone can benefit from my help here
joey20046
Nov 3, 2008 09:06 AM
addiction2bass
Apr 13, 2008 05:19 PM
jtvision
Jan 11, 2007 07:58 AM
HARI.
Oct 8, 2006 09:46 PM
ally0urb4ser
Nov 7, 2004 01:03 PM
