Starting Issues
Old Aug 14, 2010 | 02:49 PM
ctdale's Avatar
Default Starting Issues
I have a 95 Civic LX and normally when I attempt to start it, I have to turn the key on, and then wait for the check engine light to go off and hear some noise rev up before it will start. Today, the check engine light will not go off, so the car will not start. It will turn over, but appears to not get spark. Is there a relay that maybe went out? Please help. In the past, the amount of time varied from the time I turned the key on and the check engine light went off; anywhere between a couple of seconds and 5 to 10 minutes. Please advise.
Old Aug 14, 2010 | 09:47 PM
Sounds to me like a main relay problem.
But since you seem to be throwing a code since the CEL stays on, retrieve the code first.
http://www.honda-tech.com/showthread.php?t=1901557
Old Aug 15, 2010 | 07:55 AM
ctdale's Avatar
I changed the main relay and the problem still exists. The check engine light comes on and stays on. The main relay never clicks. I located the jumper on the passenger side and jumped it with a jumper wire, turned the key on and the check engine light stays solid, never flashing to indicate a code. Does this mean it is a ground or ECU issue?
Old Aug 15, 2010 | 04:36 PM
ctdale's Avatar
In addition to the check engine still staying on, the transmission is stuck in park. I turned the key on until the check engine light comes on, but the transmission will not come out of park. Any suggestions? Would this keep the CEL from going out and the main relay from clicking?
Old Aug 15, 2010 | 05:32 PM
There is a small groove beside the shifter that's just big enough for a key. Press your car key in it, then it'll shift when the engine is off.
Old Aug 16, 2010 | 08:42 AM
ctdale's Avatar
Found the key location next to the shifter and was able to get the car out of park, but was hoping by putting it in neutral it would start. No luck. Any other suggestions on the CEL staying on?
nramil
Sep 4, 2007 11:08 AM
96civichb
Jun 6, 2007 06:07 PM
totenkopf
May 31, 2007 03:36 PM
pimpciv98
Mar 26, 2007 12:22 PM
shawnpdx
May 23, 2006 07:20 PM
