steering
Old Aug 1, 2010 | 01:06 PM
Hannah20's Avatar
Default steering
i have this problem with my car just wandered if ne1 had ths problem. the steering sqeeks every time i turn the steering wheel like its grinding off something. any1 no wt this could be? thanks.
Old Aug 1, 2010 | 01:39 PM
Check the power steering fluid level, the condition of the power steering belt, and the tension of the belt. Make sure everything looks normal.
Old Aug 1, 2010 | 02:24 PM
Hannah20's Avatar
my cars 02 so its electronic power sterring so no fluid is needed iv had the belt and tension checked also!
Old Aug 1, 2010 | 02:27 PM
Alright.
Next step would be to jack up the front of the car (or preferably use a lift) and then turn the wheels through their full range of motion and look underneath and in the wheelwells for anything rubbing on anything whatsoever.
Old Aug 1, 2010 | 02:38 PM
Hannah20's Avatar
Alright.
ok thanx 4dat must get that done..most annoyinest thing eva ta listen ta wen ur drivin!!
Old Aug 1, 2010 | 11:05 PM
supersize's Avatar
Sir Banned-a-lot
is it comming from inside the cabin? because i know when its cold out, the plastics do squeek when you turn your wheel. it was happening to me and i looked it up and its a common problome.
Old Aug 1, 2010 | 11:19 PM
Dude, it's August.
Old Aug 2, 2010 | 04:14 AM
It is still a good question though, is the noise from something inside the car, or under the hood? If it's under the hood, turn the key on but don't start the engine. Then have someone turn the wheel while you listen under the hood to try to identify the source of the noise.
Old Aug 2, 2010 | 10:51 AM
Hannah20's Avatar
its coming from outside the car, something to do with the suspension.
Old Aug 2, 2010 | 11:10 AM
If the noise is not coming from the PS pump or belt, then check whether the wheel splash guard is bent and rubbing on the rotor on turns.
norbster86
Feb 11, 2010 04:52 AM
jpnolan
Apr 14, 2009 11:11 AM
prodigyskate5
Jan 21, 2009 01:13 PM
Julian
Sep 29, 2007 04:50 PM
stick only
Sep 21, 2007 05:39 PM
