Steering rack question
Old Jun 21, 2008 | 05:20 PM
kma's Avatar
kma
Default Steering rack question
I just got my steering rack replaced today because I had a leakage......there was play in my steering BEFORE the change and there still is AFTER but I gotta take it back because the mechanic forgot to line up the wheels before putting everything back together [>:], so now my wheel's sorta tilted (Gonna take it back to fix that tomorrow). But strangely, my horn doesn't work anymore. I tested the horn by activating my alarm so I know the horn still works (also checked the fuse anyway for kicks). I saw someone mention a problem with their airbags after removing steering rack. Can anyone tell me what the steering knuckle has to do with the horn suddenly not working and how to fix it?! I really can't drive without my horn, accidents are more likely here without one at night. Also, why is there still play in the steering wheel? Oh, one last thing......I noticed a few minutes ago on the way home that when I go over a speed bump it sounds like something moved....I'm strongly leaning toward the steering rack being slack or something seeing that the sound wasn't there before. So....those 3 questions.....any help is greatly appreciated. Thanks in advance.
Old Jun 21, 2008 | 05:28 PM
Default RE: Steering rack question
On a 1992 or later, the horn and air bag connect thru a "clock spring" to the wheel. If a mechanic is not real careful when working on the steering, the clock spring can get turned too far and break. The horn and air bag will not work after that happens. The fix is of course to replace the clock spring, but it's an expensive part.
There are two u-joints in the shaft between the wheel and the rack, if those are bad or the bolts are loose, there will be play in the steering. Normally they are covered up by a plastic cover in the brake pedal area, but you can remove that to inspect them.
Old Jun 21, 2008 | 05:48 PM
kma's Avatar
kma
[sm=jawdrop.gif]I DID hear something snap when I first turned the wheel after I got it back, I told the mechanic the wheel didn't feel right and he was like "don't worry about that" til I really stressed about not being comfortable with the problem. So now I guess I need a clock spring too.....where's that located exactly? I may be able to get one. I have a 96 civic lx 4dr a/t sedan. I saw a 97 civic 2 dr m/t. Not really a car person.....would the clock spring work out of that? and how hard is that to remove?
norbster86
Feb 11, 2010 04:52 AM
Julian
Sep 29, 2007 04:50 PM
DaRKoN
12
May 3, 2007 06:08 PM
TAG781
Feb 20, 2006 11:51 PM
mabus013
Jan 18, 2006 07:38 PM
