strange brake vibration
Old Apr 13, 2013 | 07:41 AM
MaximusFunk's Avatar
Default strange brake vibration
hi, I just changed my front rotor/pads/caliper/bearing/hub on one side and rotor/pads/bearing on the other. This is on a 93 accord with captive rotors, but I thought i might have better luck getting help on HCF
now when I first start to press down on the brake at speeds above 40, there is a massive vibration and i can see the steering wheel shake, but when i continue to press down on the pedal harder to come to a stop it stops perfect with no vibration.
On the caliper that I didnt replace, I made sure the piston was moving and greased the slide bolts. I did not have this problem before replacing all these parts
any idea what might be causing the problem? thanks.
Thom786
Mar 1, 2014 05:27 AM
briceman124
Apr 17, 2012 05:49 AM
jds62f
Mar 4, 2009 06:08 AM
jbum
15
Oct 4, 2005 06:39 PM
US3R!!!11one
Jun 7, 2005 02:33 PM
