sudden drop in gas mileage
Old Apr 18, 2009 | 03:39 AM
Originally Posted by kfish
...It does come on for a second with the others, but not other than that.
...Your CEL bulb is burned out or has been removed, so it could be throwing codes and you'd never know. I'd recommend replacing the bulb while you're at it.
I think the CEL is fine.
Old Apr 18, 2009 | 04:18 AM
RonJ's right. I missed a post while I was checking HCF from my phone...
Old Apr 18, 2009 | 07:47 AM
Baker has a good point about the possibility of overcooling because of a bad thermostat. If that were the case, you would see that the temperature gauge on the dash always stays at or near cold instead of coming up to the normal reading of about halfway up.
And do check that spark timing because being even a little off on the timing will kill your gas mileage with no other symptoms other than less horsepower as well.
Teeko
Jun 27, 2011 06:15 PM
bensy
Feb 11, 2009 01:08 PM
addiction2bass
22
Jun 21, 2007 08:16 AM
Motor35
Oct 6, 2006 11:13 PM
02CivicEX
Mar 6, 2005 10:45 AM
