testing coil
Old May 16, 2012 | 12:58 AM
mycam8u2's Avatar
Default testing coil
can someone tell me how to do a test on the coil of a 2000 civic? or how to test voltage coming through the wires
Old May 16, 2012 | 07:02 AM
There should be resistance of several k ohms from the output to either low-voltage terminal, and less than 1 ohm between the two small terminals. Replace a coil that fails these tests, but the resistance test will misdiagnose a lot of bad coils as good.
With the key on, the low voltage terminals should both have battery voltage to ground. Test this in both the on and start positions. For the start test, disconnect the starter so the engine doesn't actually turn. Firing a Honda coil into an open circuit is likely to damage it.
Next to the "live fire" test, the only real proof. With the distributor cap off, hold a grounded test wire near the coil output and crank. You should get blue sparks that can jump 3/4 of an inch. If you have only weak yellow sparks, the coil is bad. If no sparks at all, it could be a bad coil, or something else. Also note that if the timing belt is stripped so the distributor doesn't rotate, no sparks will fire.
Old May 16, 2012 | 07:14 PM
2012 Si's Avatar
I found out the hard way not to fire a coil into an open/no load on my old 93 LX. It passed the resistance tests but was dead.
caisson1
May 4, 2012 06:01 AM
ClinDiesel
Oct 2, 2007 06:22 AM
sacicons
Dec 18, 2005 08:21 AM
niteryder
Jan 23, 2005 06:55 PM
la tuya
Aug 19, 2004 01:52 PM
