Testing TPS
Old Jun 1, 2010 | 06:27 PM
Hank5.9's Avatar
Default Testing TPS
TPS is out of car in my signature. It has three pins, when ohming outside pins i get 4.6ohms. When either outside is ohmed with inside pin, i get .688 ohms to 4.6 ohms, when swept. Anyone got any info on doing this? While sweeping the resistance seemed pretty consistant, but at a certain point it would go from measuring #.## to #.### so is it possible at a certain point during the sweep the measurement becomes finer? any input is appreciated.
Thanks.
Old Jun 2, 2010 | 02:33 PM
Hank5.9's Avatar
Did some more digging and fingered it out. Now where abouts can I get a new tps/ or probably throttle body unit because it is rivited on? Anyone have any advice?
Old Jun 2, 2010 | 04:22 PM
SilverSedan's Avatar
you should be able to carefully drill out the rivits and then screw the new TPS in its place.
Old Jun 3, 2010 | 04:33 AM
^Indeed. If you can find a deal on just the TPS, buy it up. Use a dremel (or a hacksaw if you don't have a dremel, but DO have a steady hand!) and cut a slit into the top of the rivets. They are actually screws, they just don't have typical screw heads. Once you've got a slit in the top, use a flathead screwdriver and they will spin right out.
As for the testing... It's been about 3.5 years since I went through that process and cannot remember the target numbers. They are listed in the Manual though.
jwsimons
Feb 4, 2006 12:09 AM
sacicons
Dec 18, 2005 08:21 AM
niteryder
Jan 23, 2005 06:55 PM
la tuya
Aug 19, 2004 01:52 PM
