timing belt change
Old Apr 20, 2012 | 03:56 AM
mycam8u2's Avatar
Default timing belt change
how hard is it to change the timing belt on a 00 civic? what tools r required?
Old Apr 20, 2012 | 03:14 PM
droopy128's Avatar
Your main concern would be removing the crank pulley bolt, other than that, your basic tool would do fine.
Old Apr 23, 2012 | 01:06 PM
mycam8u2's Avatar
what timing mark do i use on the crank pulley? there is one by its self and there are 3 together
Old Apr 23, 2012 | 10:01 PM
droopy128's Avatar
Old Apr 24, 2012 | 03:44 PM
mycam8u2's Avatar
sorry. what size is the crank bolt?
Old Apr 24, 2012 | 03:54 PM
droopy128's Avatar
17mm.. use a 6 points socket if you have it.
Old Apr 25, 2012 | 01:09 AM
mycam8u2's Avatar
thanks alot bud
Old Apr 25, 2012 | 05:23 AM
There are marks inside to set the crank to TDC to install the belt, you don't need the one on the pulley. The group of three together are used to set the spark timing, which should always be done after changing the timing belt. After the bolt is out, when pulling the pulley off be careful not to lose the little metal key.
Old Apr 25, 2012 | 01:13 PM
mycam8u2's Avatar
ok. thanks
Esquirrel
28
Mar 7, 2012 02:51 PM
thakid
Jan 30, 2006 08:29 PM
powderdude
13
Sep 20, 2005 12:18 PM
ahhsimon
May 3, 2005 03:01 AM
91DXHatch
12
Dec 7, 2004 08:01 PM
