Timing Belt Noise
Old Jul 22, 2010 | 07:33 PM
Sbtflip's Avatar
Default Timing Belt Noise
1994 Honda Civic LX d15b7
Timing Belt Seems to be making noise. Got an audio recording of it.
http://www.youtube.com/watch?v=hZfUHnFb4Os
1080p Available Dont know if that helps with sound or not.
Dont mind the vibration sound on :07-0:10 camera was sitting against something that shook during increase in rpm.
Hoping to get some opinions on what the noise is?
Timing Belt too lose or tight? Idle Pulley Bearing etc.
Old Jul 22, 2010 | 07:57 PM
How do you know the sound is from the timing belt?
Old Jul 22, 2010 | 08:15 PM
Sbtflip's Avatar
I actually dont, just taking a good guess. It actually has 2 noise the other louder than this. But im able to completely eliminate it which the bottom cover of timing belt is like broken and rubs somewhere and i can take a flathead and press against it and eliminate the sound then i left with the sound that i recorded.
Old Jul 24, 2010 | 04:32 AM
Take the other belts off first and try again to be sure its related to the timing belt. Sounds more like a bad power steering pump or one running without fluid.
Old Jul 24, 2010 | 07:35 AM
honda_farmboy's Avatar
Banned
does turning the wheel affect the noise (while running)
Old Jul 24, 2010 | 05:30 PM
Sbtflip's Avatar
Does seem to, certain places of turning wheel it will speed up/slowdown and be louder/quieter.
At one point turned all the way to left where it holds it self, and then if i add a little more pressure to wheel its very noticeable of going quieter.
Old Jul 26, 2010 | 10:15 AM
Sbtflip's Avatar
(removed)
smackpower
Jan 13, 2024 01:42 AM
Kyle700
Sep 18, 2014 07:44 PM
pippo
Jan 26, 2010 02:40 PM
nardva
Oct 8, 2005 12:58 PM
bleedhondos
May 19, 2005 04:31 PM
