timing belt pulley key broke
Old Apr 17, 2012 | 05:41 AM
kedwards0408's Avatar
Default timing belt pulley key broke
1992 Civic LX, 1.5l sohc exiting expressway and car died. Turned out that the timing belt pulley woodruff key broke. This pulley is a one piece aluminum, the key is part of the pulley so the whole pulley has to be replaced. I replaced the pulley started up ran fine for about ten minutes and then died. Same thing happened. I am a little stumped, has anyone else ever experienced this before?
Old Apr 17, 2012 | 05:43 AM
The bolt needs to be really tight; it holds everything together. Make sure you have the guide washers in place on both sides of the timing belt pulley.
Old Apr 17, 2012 | 09:16 AM
phillip lizotte's Avatar
it needs to be really tight,i just went thru this and stripped my main crank out so bad i had to replace the motor.tork it down,or have a shop do it.i let it go and it cost me big.on a high point,its never ran better,800 bucks later
Old Apr 17, 2012 | 11:33 AM
So the person who did some work on this a month or so ago did not tighten the bolt enough and it took a month or so to break? Then the second one broke in 10 minutes?
StonedCold
Nov 17, 2011 01:34 PM
ChasingAdrenaline
May 27, 2010 07:25 PM
og_281
Apr 19, 2008 03:23 PM
tonguetwiztid
Jul 19, 2006 10:13 PM
ef4life
Apr 25, 2006 08:00 AM
