Timing Belt Snapped On a 96 1.4 Civic Need Help ? :( ?
Old Apr 27, 2009 | 03:32 PM
devanecivic's Avatar
Unhappy Timing Belt Snapped On a 96 1.4 Civic Need Help ? :( ?
Timing Belt Snapped On a 96 1.4 Civic Need Help ? ?
Hi a friend of mine has a 1.4 1996 ek3 civic the timing belt snapped on it. they tried tow starting to see would it turn over but all the got was a tearing noise so they stopped straight away anyone have an idea wether there is a point of going to all the work of putting a timing belt back on.or has damage been done help needed fast ?? thanks !
Old Apr 27, 2009 | 03:59 PM
All honda engines are interference engines. That means when the timing belt snaps, your pistons and valves get slapped. That engine is likely toast.
Old Apr 27, 2009 | 05:08 PM
Once in a while, for reasons unclear to me, the engine is spared after the timing belt snaps. Properly install a new belt and then compression test the cylinders (click Compression link in my signature).
Old Apr 28, 2009 | 06:33 AM
You could check the valves with a leakdown test before replacing the belt. Set the cam by hand so all valves on the cylinder under test are closed.
It's also not that hard to just put a new belt on and see if it will run.
twiser21
Apr 1, 2013 06:12 AM
fq2255
Jul 26, 2011 08:56 AM
pippo
Jan 26, 2010 02:40 PM
wookieneck
Nov 7, 2008 12:32 PM
oobi
Mar 1, 2008 06:32 PM
