Towing all-wheels down
Old Mar 5, 2012 | 10:52 AM
flyn2lo48's Avatar
Default Towing all-wheels down
Honda Manual for my 2008 Civic/5spd states that towing all-wheels down should be limited to 50mph, max 35 miles. Does anyone have experience towing their Manual trans Civic behind a motor home? In spite of what Honda says, I can't see it damaging the car and its manual trans; it's just coasting behind the RV. It's assumed, of course, that the ignition switch is positioned to allow the steering wheel to free-wheel.
Old Mar 5, 2012 | 11:04 AM
I really can't see anything wrong with going over 35 miles, with the exception of the odometer recording mileage during the trip, and the tires being used up. Someone correct me if I am wrong.
Old Apr 3, 2012 | 09:31 AM
phillip lizotte's Avatar
my friend has a 07' honda hatchback that gets towed behind the rv all summer long..and its the only time it gets moved...shameful.i wouldnt think its hurting anything but your odometer.
Old Apr 4, 2012 | 04:32 AM
flyn2lo48's Avatar
Default Flat tow
I have to agree. I have noticed some abnormal front tire tread wear, though I am certain the alignment is fine. That could be explained by the car wandering some under tow. Regardless, I'm pressing on as is.
Thanks,
John
Old Apr 4, 2012 | 01:07 PM
civic2001's Avatar
I have towed our 2007 Civic 5 speed Manual 4 down for about 5 years now. I have a battery quick disconnet because when the key is in accessories position it consumes battery power.
Old Apr 5, 2012 | 04:02 AM
flyn2lo48's Avatar
That's something I hadn't considered, but I'll look into it.
Old Apr 5, 2012 | 06:34 AM
boiler1's Avatar
I would look into whether or not the transmission is being properly lubricated and cooled when being towed with the drive wheels on the ground. I know via hearsay that some cars this is the issue and the reason why I'd be cautious going against the owners manual. I'm never worked on the innerds of manual transmission, but surely some sort of pump is required to lubricate everything. If its not pumping while in neutral, it'd obviously be a problem...
MellowYellow
Apr 8, 2009 10:15 AM
Intrepid175
Jul 12, 2006 11:42 PM
barrynfla
Nov 14, 2005 08:10 PM
eliteturtle7
Jul 6, 2005 09:32 PM
opa3x
Jan 24, 2005 09:44 PM
