Trans Fluid change
Old Apr 26, 2007 | 09:33 PM
Live_4it's Avatar
Default RE: Trans Fluid change
I'm sure transmission fluid could go the whole life ofa car, but imo it's not gonna be as crisp. Mine doesn't smoothly go into gears as good as it used to, I think it will be able to slide through gears better after a change. Well I'll post after I change it and see if it makes a difference.
And no I don't grind my gears all the time.....
Old Apr 26, 2007 | 10:00 PM
mill$civic's Avatar
I changed mine because I had no record when it was last changed and I needed to change the fluid to stop the grinding in second with some GM synchromesh...and it worked..
Old Apr 26, 2007 | 10:06 PM
ic892003's Avatar
niceeeeee.... mills u have an automatic tho rite?
Old Apr 26, 2007 | 11:40 PM
riceburner700's Avatar
im pretty sure he has a manuel.
you have to be careful with flushing automatic transmissions because if the clutch plate friction material weres off and stays in the tranny fluid the trannsmission will still work. when you dain the fluid the friction material will come out. you put in the new stuff and your transmission has nothing to grab with. Dont loet this scare you though, if you havent beaten on your tranny you should be fine with an auto. if you have a manuel its a piece of cake, just drain and fill
Old Apr 27, 2007 | 03:52 PM
mill$civic's Avatar
ORIGINAL: ic892003
No I do not. Stick.
Old Apr 27, 2007 | 09:42 PM
ic892003's Avatar
oh ok, i have a stick also, ill jus follow ur diy thanks mills, im gunna try to pry that stupid filler bolt off.....
Old Jun 1, 2007 | 05:35 AM
my94civic's Avatar
can i get hold of GM synchromesh in any, motor shop, or is it generaly available online??
FastEG
Oct 24, 2010 07:21 AM
iwishiwasemo89
Jul 27, 2007 12:07 PM
rajantsr
May 18, 2006 06:29 PM
Toppers
Feb 2, 2006 01:30 PM
amsmk
Jan 10, 2006 09:33 PM
