Turbo Help
Old Dec 24, 2008 | 09:38 AM
Jakkerus's Avatar
Default Turbo Help
So I know somewhat about car engines and that sort of thing, but turbos are a whole different world I don't know alot about what I'm looking for which brings me to my question what am I looking for in purchasing a turbo/kit and what do i need to do be prepared for putting something like that in my car I have a 2005 Civic coupe with and I have a k20 on order to drop into it (maybe needs it own thread but thought i'd add it in does anyone know where to find the mounting hardware for this swap and what all I'll need) any help is greatly appreciated thanks!
Old Dec 24, 2008 | 10:06 AM
Okay, I know it's not going to answer your question, per se, but I'd recommend doing a good bit of research and reading before trying something as in-depth as a turbo kit. Also, k20 swaps aren't exactly a beginner's task, so I'd do some research on that.
For the k20 swap, check hasport's shopping list... it tells you pretty much everything you need to do the swap (technically the list is for an '01/'02 civic but it should be the same for an '05).
Old Dec 24, 2008 | 10:17 AM
munkeewrench23's Avatar
which k20 do you have? the type s motor? the 07 si? or the reg 02-04 si or rsx base model? if its the reg rsx or si base model dont even bother turboing those they are weak for turbo if you have the type s k20 then you should be fine. but turboing gets expensive with the high octane fuel that you have to pump and it drinks it up fast. garrett makes good turbos. you can also buy a complete kit from greddy minus the intercooler thats seperate but you can go ebay with that, dont buy a ebay turbo kit even if its cheap, the turbos from ebay are crap unless its a true garrett, but anyways for kseries i actually recommend going supercharger from jackson racing you will get reliability and power, but you can make more power with turbo...just research it more read magazines, and other forums to get a clearer idea on whats involved.
soldout712
12
Oct 30, 2006 11:05 PM
forrealb50
Mar 29, 2006 07:57 AM
Jas10hon
Jul 4, 2005 10:35 PM
TrailorParkPimp
Aug 28, 2004 12:21 PM
