Update on 1997 Civic that wont start
Old May 7, 2011 | 08:10 AM
jdeb's Avatar
Default Update on 1997 Civic that wont start, Fixed, Thanks
Cleaning the battery terminals did the trick. Thanks for the help.
Old May 7, 2011 | 09:34 AM
Don't start new threads about the same problem.
I stand by my original diagnosis. It takes more power to run the brake lights than it seems your battery is able to deliver. Try jump-starting the car.
Old May 7, 2011 | 04:50 PM
conceptualpolymer's Avatar
I'll bet you have a loose or corroded battery terminal. Tighten both, first and if that doesn't work, clean each and retighten. Of course, it could be the connection at the engine block (ground) but more likely, it is at the battery terminals.
Old May 8, 2011 | 01:14 PM
jdeb's Avatar
Cleaning the battery terminals fixed the problem.
Old May 8, 2011 | 01:28 PM
I just recently had the same problem. It was the positive battery connection that was loose. I'm glad to see it was that simple of a fix for you as well.
redlines4us
Apr 25, 2021 06:20 PM
David_S
Oct 24, 2013 10:06 AM
rafi_l
Mar 25, 2012 07:11 AM
bmelloh
May 16, 2009 08:01 PM
315 Customs
Oct 17, 2006 08:22 PM
