Vibrations when braking
Old Oct 3, 2007 | 11:07 PM
xr21's Avatar
Default Vibrations when braking
sometimes when I brake while going over 60 miles/h, my steering starts vibrating. Could this be an alignment/wheel balancing issue?
Old Oct 3, 2007 | 11:38 PM
Hailchristian's Avatar
Default RE: Vibrations when braking
could be warped rotors.....i had the same problem, slapped some new rotors on it and it stops smooth every time now.
Old Oct 4, 2007 | 03:26 AM
kinosh's Avatar
Yep, I'll second that, especially if you haven't serviced your brakes recently.
Old Oct 5, 2007 | 02:15 PM
xr21's Avatar
can warped rotors be a serious issue? I really dont care about the vibrations as long as it doesnt compromise safety.
Old Oct 5, 2007 | 02:42 PM
91JDMB16A's Avatar
if i'm not mistaken if your rotors are warped then your brake pads aren't touching the rotor evenly hence the vibration
Old Oct 5, 2007 | 03:32 PM
ryank327's Avatar
Warped rotors can cause decreased braking efficiency and increase the wear of the brake pads. I'd suggest getting them replaced.
Old Oct 5, 2007 | 03:34 PM
Pete's Avatar
replacing brakes is soo easy. I will do a diy when I need new ones.
Old Oct 5, 2007 | 03:40 PM
ryank327's Avatar
http://www.honda-tech.com/zerothread?id=1938057
I just happened to be reading that haha, good stuff.
AudibleAura
Aug 29, 2007 08:38 PM
bakertime
13
Mar 13, 2007 09:32 PM
green98lxsedan
Jan 10, 2005 09:49 PM
duke
Dec 21, 2004 08:32 PM
nwhite82
Dec 19, 2004 01:04 AM
