What should I do new engine or replace the crank ?
Old Sep 4, 2018 | 07:08 PM
Rey rey's Avatar
Default What should I do new engine or replace the crank ?
Hello I have a 1998 Honda Civic ex d16y7 and well this happened
Old Sep 8, 2018 | 07:08 AM
How much money do you want to spend?
Do you have the technical capabilities to remove the engine and reinstall yourself? How about replacing the crank? Also, replacing the crank isn't just a bit in and go like brakes, or a sway bar. It needs new properly-sized bearings and a lot of know-how to get it right. I don't even trust myself to do something like that. You'd end up taking it to a machine shop most likely where a new motor would only cost a few hundred bucks.
Also, the y7 isn't the factory motor for the USDM EX so it's been swapped before, why not just put another motor in it?
Old Sep 8, 2018 | 07:38 AM
Rey rey's Avatar
Default Oh I went with a new engine
I've talked it over with my mechanic another engine is only around 500 so I'll go with that, weird that it came with the y7 I bought the car from an old lady for about 200 cuz other mechanical problems that I've already dealt with. Thanks for the advice.
phillip lizotte
Apr 12, 2012 09:33 AM
chrismag
Jan 5, 2010 03:08 PM
reignstarz
Apr 23, 2009 05:57 AM
slowcivicdriver
Dec 24, 2006 10:12 AM
boostnub
Nov 8, 2006 01:17 PM
