whats the deal with over dive?
Old Dec 21, 2005 | 07:53 PM
as7413's Avatar
Default whats the deal with over dive?
explain the over drive option please...
Old Dec 22, 2005 | 05:38 AM
AOL.COM's Avatar
Default RE: whats the deal with over dive?
overdrive provides a 1 to 1 ratio between engine & trans (it means that the the tranny is turning at the same speed as the engine) it kicks in at about 50-60 mph
it also gives u better gas mileage
Old Dec 22, 2005 | 05:54 AM
99civic_boosted's Avatar
Actually Drive provides the "1:1" ratio. Overdrive is usually more like a "0.7:1" less then a 1:1 ratio.
First Gear would be something like "2.3:1"
Second gear would be somewhere around "1.5:1"
Third or Drive = "1:1"
Overdrive = "0.7:1"
Old Dec 22, 2005 | 09:36 AM
leco516's Avatar
overdrive is another gear unit that installs on the tailshaft of the transmission
and the driveshaft connects to the other end. it is a gear box either
with 1:1 gear ratio or 1:1.5 . They can be installed on any car but the
driveshaft will have to be shortened to accomodate the length of the
overdrive unit. better to buy it as an option. The purpose is lower rpm
at highway speed and much better gas milage on the highway.
on front drive cars this would be another gear inside the transmission.
Old Dec 23, 2005 | 07:20 AM
97 Black Civic's Avatar
Not only will it give you better gas mileage but it will also increase engine life. If you do alot of highway cruising having overdrive will drop your rpms dramatically.
tano001
Jul 28, 2008 04:21 PM
Civic Si 00
Dec 26, 2007 04:02 PM
TBH_u_sw0ll0w
Nov 12, 2007 10:43 AM
DreamTeam87
Oct 9, 2007 12:32 PM
96civic285whp
Sep 19, 2006 08:32 PM
