View Poll Results: What should I start with....
Distributor about $150-$180
40.00%
Rear Brakes Have not checked the price yet...
0%
the 1 known bad tie rod.... I think its actually called a rack end... about $20
40.00%
Both rack ends and both tie rod ends... about $80...
20.00%
Voters: 5. You may not vote on this poll
Where to begin....
Old Apr 15, 2010 | 02:15 PM
THE_FATTIE's Avatar
Default Where to begin....
Alright.... I have some known issuses with my car and technically they all need to be fixed... Im just not sure where to start and whats more important... I have 2 catagorys.... 1 Urgent and 2 Important.... Any advice would be greatly appreciated...
1-1 Rear brakes- they are making a repulsive sound when I brake... I have only done drums once and im not sure I have all the tools I need to get them done..
1-2 Distributor... Needs to be replaced... I have oil inside my cap and it leaks down onto my engine/trans...
1-3 driver side inner tie rod... I can get the tie rods and the tie rod ends for $18 a pop from autozone... Should I do all 4 or just the bad one?
I think thats all the major things...
2 interior lighting/ blower motor or fan switch.... Important but the car will get me back and forth to work without... Ill make it a pole.... Let me know what you think.... Thanks in advance...
Old Apr 15, 2010 | 03:50 PM
apoplectic1's Avatar
I would do the distributor first. If that goes, your car wont. Then I would take care of the tie rods and rack ends. The brakes last if there is indeed a problem with them.
Old Apr 15, 2010 | 05:58 PM
THE_FATTIE's Avatar
Bump...
Old Apr 15, 2010 | 06:28 PM
Kenny-g's Avatar
I'm Spock Dammit!!!!!
^ i agree...plus its the most expensive one on ur list so knock it out right away.
Old Apr 15, 2010 | 11:54 PM
Tie rods first... bad tie rods equates to a really bad alignment, which equates to tires being chewed through quickly. Do you want to have to buy new tires too?
Apostle
17
Aug 21, 2008 01:35 PM
Emt645
Apr 2, 2007 02:28 PM
JessicaRT
Jul 12, 2006 04:27 PM
Fiirkan
Mar 9, 2006 04:26 PM
