why is my car running so rich?
Old Feb 14, 2008 | 11:40 AM
hondaT's Avatar
Default why is my car running so rich?
i just did a b16 swap in my honda and its running really rich..why?
Old Feb 14, 2008 | 12:07 PM
Default RE: why is my car running so rich?
What makes you think the engine is running rich? Do you have a CEL?
Information supplied from the primary O2 sensor to the ECU functions to determine proper air/fuel ratios.
Old Feb 14, 2008 | 05:09 PM
hondaT's Avatar
It's running real bad on gas mileage. Yes, the CEL is on.
I'm not exactly sure what your talking about. Could you put it a bit simpler?
Old Feb 14, 2008 | 05:13 PM
The computer reads the O2 sensor to determine if the engine is running rich. If it is it tries to reduce the fuel mixture. If that is not successful it sets a code and turns on the CEL.
Make sure the little vacuum hose on the end of the fuel pressure regulator is hooked up properly. If not you will have too much fuel pressure and a rich condition.
Old Feb 14, 2008 | 05:23 PM
ORIGINAL: hondaT
Yes, the CEL is on.
Retrieve the CEL code yourself as detailed here:
http://www.honda-tech.com/zerothread/1901557
Clear the CEL code and verify that the same code(s) is again thrown. Troubleshooting repeated codes should reveal the reason for your poor gas mileage, which I suspect will be due to a fault in the primary oxygen sensor system.
Old Feb 14, 2008 | 05:35 PM
civic_burns_all's Avatar
get the CEL codes and tell us what it says
Old Feb 14, 2008 | 05:56 PM
Yes if the sensor is bad it will also run rich and turn on the CEL, but with a different code than if it is rich for some other reason.
bcrichguitars
27
Jan 14, 2011 06:12 PM
scottdh20
Nov 24, 2007 07:50 PM
Tabemono
Aug 20, 2007 09:12 AM
JDMracer00
Jul 6, 2005 04:11 PM
AnakinKenobe
Apr 23, 2005 07:07 PM
