will it work
Old Apr 2, 2005 | 10:19 PM
crx247's Avatar
Default will it work
i ahve an 89 crx si with a wore out motor. i have a buddy with a stock dseries engine out of a 98 civic. will my stock 89 si intake and exhaust manifolds work on this motor? will my clutch and flywheel bot on it? how about my distributor??? if i use my 89 si motor mounts, will they bolt to the motor and line up?
i was hoping to bolt this engine in my car...will it work??
thanks!
Old Apr 3, 2005 | 11:37 PM
finalimpact's Avatar
Default RE: will it work
im currently running a d16y7 out of the 96-00 civics. all your manifolds will bolt up, your clutch and flywheel will transfer over, and you will be required to use your 89 motor mount bracket(both the rubber and the bracket which bolts to your block) and your distributor will bolt up just fine.
x1mpr0x
Sep 4, 2009 07:44 PM
muuurph
19
Oct 25, 2008 09:09 AM
importcivicus
Mar 15, 2006 08:28 PM
lilol89crx
Jul 29, 2004 06:56 PM
drrocket0302
Jul 20, 2004 11:30 PM
