Winter starting problem and rough idle
Old Jan 19, 2009 | 07:00 PM
mundy5's Avatar
got it RonJ. Let's hope that these 2 folks will clean out their IACVs and see what happens next.
Old Jan 20, 2009 | 12:00 AM
low35's Avatar
Ok,
I did not mention I am using the y7 mani still (I assume you guys thought is was using the y8). I read in a few places that the common problem with this setup is a rough idle. Is this true? I just got done cleaning the IACV (that sucker is tucked away good), it had mass amounts of crud in it, I also cleaned the tb. I have not driven it yet (3am right now). I will let you guys know if it helped at all.
Old Jan 20, 2009 | 10:44 PM
low35's Avatar
well,
I took it for a long ride today and still have the idle issue. It also seems to have a lag in throttle response and choppy acceleration. I assume I am having a fuel system issue. The funny thing is that these problems (excluding idle) seem to come and go. Any ideas?
Old Jan 21, 2009 | 05:20 AM
Edit:
Does the CEL work? Does it now stay ON when you are driving?
Below are two more IACV tests.
1) Do this test with a warm engine that is idling:
2) Disconnect the IACV connector and then measure the resistance (Ohms) across the indicated terminals of the IACV (the valve not the wire harness connector):
tyhodge07
Jun 27, 2013 09:50 AM
KingofSparta
Feb 8, 2011 05:00 AM
whittier97370
Aug 29, 2010 04:41 PM
Stumasters
Jan 20, 2008 12:58 PM
zpinklilpink
Jun 18, 2007 11:24 AM
