Wiring check | Viper 5002
1998 Honda Civic EX Sedan 5-Speed
Viper 5002 alarm system
Can you please look this over, make sure everything looks OK. This is my first alarm install. I just want to make sure I do this right the first time.
520T Battery Backup Module
RED .. (15A fuse 12” from power source) to 12V Constant [18 gauge wire]
GRAY (+) 12V Output - to Viper (+) 12V Constant
BLACK .. GROUND to Chassis
BLUE (-) Output to Control Module - tap H2/2 GREY (-) Hood Pin Input, Zone 6 (22 gauge)
Parking Light Flash Relay
86+87 .. tap 520T RED +12v Constant
30 .. tap Parking Lights (+) RED/Black (drivers door sill/front of the fusebox)
85 .. to H1/11 WHITE [set to neg. output with jumper on the side of brain]
Relay for 2 sirens (30 amp SPDT)
30 .. to sirens
85 .. to H2/7 LIGHT BROWN (set to constant output in menu with program switch)
H1 Harness
H1/1 .. NOT NEEDED (is for trunk pop, you can add an actuator and relay to do so if you want)
H1/2 .. to 520T GRAY (15A fuse on Viper side)
H1/3 .. to 2 sirens RED (split wires, and place a 1A fuse on the one under hood to protect from grounding)
H1/4 .. tap into Ignition BLACK/YELLOW (ignition switch harness)
H1/5 .. GROUND
H1/6 .. NOT USED
H1/7 .. to Trunk BLUE/BLACK
H1/8 .. JOIN with H1/9 to (door trigger = light green/red (-)
H1/9 .. JOIN with H1/8 to (door trigger = light green/red (-)
H1/10 .. NOT USED
H1/11 .. to 85 Parking Light Flash Relay [set to neg. output with jumper on the side of brain]
H1/12 .. NOT NEEDED (is for kill relays, window/sunroof mod., led scanners, piggyback voice modules, etc)
H2 Harness
H2/1 .. NOT NEEDED
H2/2 .. to hood pin (18 gauge wire)
H2/3 .. NOT NEEDED
H2/4 .. NOT NEEDED
H2/5 .. NOT NEEDED
H2/6 .. NOT NEEDED
H2/7 .. to Siren Relay 85 (set to constant output in menu with program switch)
H2/8 .. NOT NEEDED
H3 Harness
H3/A .. GROUND
H3/B .. NOT USED
H3/C .. to neg. output door lock = green/white (-)
H3/D .. GROUND
H3/E .. NOT USED
H3/F .. to neg. output door unlock = green/orange (-)
H3/G .. GROUND
Sensor 2
507T Audio sensor
Sensor 3
507M Tilt Sensor
Immobilizer
(Normally Closed)
87a GREEN/BLACK to Starter side (power side)
..cut Starter BLACK/WHITE (ignition switch harness)
30 GREEN/WHITE to ignition side (load side of wire)
30 .. to sirens
H1 Harness
H1/5 .. GROUND
H1/6 .. NOT USED
H1/10 .. NOT USED
H2 Harness
H2/1 .. NOT NEEDED
H2/3 .. NOT NEEDED
H2/4 .. NOT NEEDED
H2/5 .. NOT NEEDED
H2/6 .. NOT NEEDED
H2/8 .. NOT NEEDED
H3 Harness
H3/A .. GROUND
H3/B .. NOT USED
H3/D .. GROUND
H3/E .. NOT USED
H3/G .. GROUND
Sensor 2
507T Audio sensor
Sensor 3
507M Tilt Sensor
Immobilizer
(Normally Closed)
Karado58
Oct 4, 2009 04:26 PM
Karado58
Sep 30, 2009 10:55 AM
