Does anybody have a jackson racing supercharger?
Old Feb 14, 2005 | 01:37 AM
  #31
Remmy's Avatar
Default RE: Does anybody have a jackson racing supercharger?
[sm=smiley32.gif]
Old Feb 14, 2005 | 03:01 AM
  #32
Kappa22's Avatar
He called you a noob... and you applauded him!
Old Feb 14, 2005 | 09:13 AM
  #33
Remmy's Avatar
It wasnt what he meant. He was pointing that subject out to everybody. I appluaded him because he managed to make absolute sense. I know im a noob but I do understand what is involved in a s/c and how it works.
Old Feb 14, 2005 | 09:33 AM
  #34
polo708's Avatar
Definately, a s/c is easier and less complex. If you want reliability then go with a supercharger.
One of the things i simply like about a turbo is that the difference between low boost and high boost (for me anyway) is simply the push of a button away. With a supercharger its a different pully.
Like said, boost varies with alot of things: pulleys, running an intake, opening up the exhaust, even driving up a steep hill will increase boost. I can cruise at highway speeds with minimal boost and in less than a second be up to full boost.
there's a good chance you'll run into traction problems with a SC (in a FF 4 banger) unless you ride the clutch like a ten dollar hooker.
I dont have too much of a traction issue, but im running motor mounts and a stiff suspension. Also, Turbos have an engine wearing issue called "surging" which will wear on an engine also.
FINAL THOUGHT: both are great, its just what kind of setup you are looking for, and a s/c is in NO WAY inferior to a turbo. For the setup you are wanting (low maint. and reliability) a blower is a great choice.
Old Feb 14, 2005 | 10:07 AM
  #35
red91civicDX's Avatar
Correctamundo
Remington and I spent at least an hour on the phone last night talking about all this. I don't hate Turbos. Don't misunderstand me. I prefer a SC for the way I drive. Instant always-on at ANY RPM boost. With no extra stress on engine oil.
For you that may not be true, you may want only the higher rpm boost.
I just want to make sure SC's get as much of a chance as Turbo's, and don't get a bad rep. There's a reason that SC's are out there, and in use in many applications (including from the factory).
To add one other thing....about the Tach....you don't need one, but you DO need a boost gauge. Go small, and it won't be obtrusive.
Old Feb 14, 2005 | 10:30 AM
  #36
Remmy's Avatar
ahh... nirvana at last!
Old Feb 14, 2005 | 02:47 PM
  #37
Kappa22's Avatar
Sorry rem, I wasn't really trying to make fun of you; a lot of people on this thread got kinda serious, so I was trying to lighten up a bit...
I guess I should have been more specific; I was basically talking about Civics (I don't know if you have a S/C Civ... thought you just had the 'Rolla.) But like I said before, in a stock base 4G hatch, you can spin the tires for a good long time with that 70 hp... Civics are just too light for low-end grunt.
And I love how the people who push S/C's are always like, "blowers and turbos are equally good, but here's why blowers are better..." So I'm done trying to argue for turbos in this thread anymore...
Old Feb 14, 2005 | 02:57 PM
  #38
I can lay an easy 30' of rubber with my SSEi on dry, clean pavement. But it's all in how you manage it. I launch at the dragstrip with hardly a tire squeak. Traction is something to manage, not something to dictate what type of FI you go with. A turbo
Old Feb 14, 2005 | 03:13 PM
  #39
Kappa22's Avatar
Have you ever driven a blown Civic? Or even a B-series swap? They can go through tires like you wouldn't believe if you're not careful, but you really don't know until you go there. Like I said, an SSEi has a lot more front-end weight, so it's not exactly on the same plane of comparison.
The biggest problem with that theory when applied to a blown Civ is that, while you're trying to "manage traction," you're burning the clutch down to the rivets. This is not a questionable fact; you can't ride the clutch through that much torque for the sake of traction and expect it to hold up. Replace the clutch? Sure, but a 6-pot will kick hard enough to have the tires going again in no time. And as for wanting to lay patches, I can light up all four tires on my otherwise stock T3/T04 DSM if I feel the desire to, and that's only about 220 turbocharged ft/lbs to all four wheels; you don't need "low-end torque" to do that...
Basically, I just think rem will find himself in a similar situation in no time; that's all.
I'm going to class now, so I won't be able to respond for quite a while...
Old Feb 14, 2005 | 03:48 PM
  #40
Remmy's Avatar
no hard feelings, i wasnt stomping you in my reply if you felt that.
