how much boost on a stock civic
Old Jun 19, 2006 | 02:16 PM
thakid's Avatar
Default how much boost on a stock civic
can any one help me out on some info on turbocarging a 16 valve D15. what is the most amount of boost i can run on a stock civic with minimal changes to fuel and ignition and what parts i need to get.
Old Jun 20, 2006 | 09:23 AM
Default RE: how much boost on a stock civic
S E A R C H !
Old Jun 20, 2006 | 10:55 AM
My04Civic's Avatar
Administrator
haha nothing pisses off ^^ Forty04 more haha
Old Jun 21, 2006 | 03:22 AM
kbeers's Avatar
I just turbo'd my D15, and I boost it to about 6 PSI. If your car has a lot of miles on it, and you dont' have it tuned properly, I wouldn't go any higher than 5-6 PSI.
Old Jun 21, 2006 | 11:20 AM
larsenracing's Avatar
Even at 5-6 psi id make sure its properly tuned if your going to spend the money to turbo it then dont half *** it do it right and get some sort of tunning device even if its just an AFC which are very usefull and enough fuel and ignition supporting mods to get you to the right A/F ratios with out Knock and then you can start to play. PS> dont tune with a norrow band A/F ratio guage get a wideband 02 sensor and some sort of logging device also a EGT can be helpful or you can opt for a dyno tune which is nice to do once in a while to so you know where you HP and TQ #'s are anyway. Good luck.
Littlehag
Jan 19, 2021 09:49 AM
tombakers
Feb 13, 2007 10:49 AM
Street Sniper
35
Dec 8, 2005 01:47 AM
str8racn
Nov 10, 2005 11:53 AM
89dxhatch
Mar 23, 2005 02:42 PM
