I think ive blown my motor! HELP
#21
RE: I think ive blown my motor! HELP
You were not running insanely rich. If you did, your motor would cut off. I have a b16 and I have experience with it. B16 will get hot very easily and you have to have it a little rich or your motor will eventually blow. I dont think you have just a ring problem. I think and can promise you that there are chunks missing out of your pistons.
A VAFC is only a bandaid to get you by until you get to a shop with a chipped ecu or a stand alone setup.
#22
tuning a turbo with just an A/F Computer is always a bad idea man. ad yeah if you were running rich you wouldnt have blown, you would just be bogging down and getting horrible MPG
#23
Sounds like your engine injested itself, IE you put a few holes in your pistons. I'd check your turbo while you're at it, I'd be surprised if you didn't destroy some of the exhaust fins if you did what I think you did to that engine.
I said get a chipped ECU and have it tuned... not get a VAFC and have it haggle crapped and called "tuned." [&:]
Running rich would have possibly caused you to wash out the rings and have insanely high EGTs which is probably how you probably melted the pistons.
