SS Auto Project
Old Jun 22, 2006 | 11:27 PM
  #111
Nail I3unny's Avatar
Default RE: 97's SS Auto Project
its entirely possible with those injectors.
Old Jun 22, 2006 | 11:28 PM
  #112
97civicturbo's Avatar
Old Jun 22, 2006 | 11:30 PM
  #113
I'm going to go throw my walbro in and see what happens. BE back in a BIT
Old Jun 23, 2006 | 12:32 AM
  #114
riceburner700's Avatar
did you try running any colder plugs, i know that my car "DOES NOT" like plugs that are older than like 2 months it starts to sputter and run really badly, but when i pop some bran new ones in it runns like a champ until they go bad in like 2 months..just and idea
looks really good though,
Old Jun 23, 2006 | 01:12 AM
  #115
*drools* pretty.....
Old Jun 24, 2006 | 11:56 PM
  #116
Sleepin95CivicDX's Avatar
this seems like there's been a pretty good amount of problems with this install so far... it looks great and everything, but everytime i check back, i see something else thats gone wrong. i dunno, hopefully it'll turn out to be a good kit, because im looking into getting a kit as well, and this SS auto looks pretty good to me, keep it up!
Old Jun 25, 2006 | 01:09 PM
  #117
hehe that's because this is my first turbo install and I'm pretty much doing it all myself [8D] None of the "PARTS" have failed yet, most of the problems have been install related.
Old Jun 25, 2006 | 01:14 PM
  #118
Marty's Avatar
Atleast you admit to it and not blame it on other things
Old Jul 1, 2006 | 05:00 PM
  #119
turbo t's Avatar
OK MATE FOR YOUR A/F RATIO
You are aimong for around 15-16 at idle and cruise , the reason it s bk firing is b cause its far too rich on my first build on a ford zetec turbo
i ran 15.7@idle and 12.5@ at wot running 10 psi of boost
if you are tuning with wideband a/f gauge look for around 15 as a starting point ,this should be good enough to get u up to initial spool up then start puting in loads more fuel
to be safe when the turbo spools up look to be around 11.2-5 then slowly start leaning it of to the point of slight det , you can buy det cans or make them OR TAKE IT TO A TUNER LOL
also cosiderations of your timing is also very crutial max advance before the turbo kicks in the retard it when the boost comes in to a point of det then retard further 3 degrees
running rich is good for safe but to a limit all it dose is slows down the burn SLOWER BURN= LESS POWER
my advice the way i have been tought to set up my turbo setup
hope this helps
Old Jul 8, 2006 | 06:24 PM
  #120
idontknowmuch's Avatar
so what happened next? did the turbo came through?
