Tuned
radiator fixed, whoop. Thermostat was all it was, going to do some more work on the oil leak situation, hairspray my charge pipes and try and find an IACV somewhere for less than $150 tomorrow.
Flip, I want to clarify my earlier comment about your idle problem. Take it or leave it as you see fit. The test that you mentioned to determine that you have a bad IACV was not definitive. The problem actually could be an intake air or vacuum leak or even a faulty coolant temperature sensor. Regarding the latter, have you bled the cooling system? To save yourself time and money, I would recommend that you do the test mentioned in my earlier post.
In addition, if the IACV were indeed the problem, why not try cleaning it first before purchasing a new one?
Just curious, why are you confident that the IACV is the problem? Did you block the throttle body port with your finger? If you did and the idle speed did not change, then you have a vacuum leak or a faulty coolant sensor. (I am a big nag, right? Just ask my kids.)
Crome isn't as bad as some people think. You can do many things depending on the version you use and how talented the tuner is with it. My buddy's running crome in an ek pushing 200~220 whp on a z6 for about 45,000 miles so far, and it still runs like a champ.
the CEL i pulled is the IACV, and whenver the tuner disabled/enable the IACV when he was tuning the CEL came off and on respectively, and then when he pulled the CEL it just to check it was still the IACV. He also explained my erratic idle as being my ECU trying to compensate for hte extra air getting brought in by the IACV, so i kept going lean, rich, lean, rich, over and over again due to the IACV being stuck open. I guess in the end i know thats what it is becasue thats what the CEL code was.
