Turbo?
lol. It's a valid question. Depending on what you're looking for powerwise/what RPM it spools at there are various turbo sizes you would want. I can't answer that question as I don't know that specific information about which turbos produce what power and when they spool. I can tell you though that bigger turbos produce more power at 8psi compared to a smaller turbo at 8psi. However, the bigger the turbo, the longer the spool lag. Do some searching to figure out which turbo would best suit your needs.
Heres a good place to start http://www.beesandgoats.com/boostfaq...rbo.html#Turbo
It says for integra but same principles apply, depending on the turbo manifold, and turbo size there are different fitting arrangements you'll need to figure out. Some are easier than others, some require getting rid of A/C, power steering, and even cutting off some metal on the tranny.
soldout712
12
Oct 30, 2006 11:05 PM
eg9
May 22, 2006 04:43 PM
forrealb50
Mar 29, 2006 07:57 AM
TrailorParkPimp
Aug 28, 2004 12:21 PM
