Turbo came in the mail today.
Old 09-10-2005, 10:34 AM
sacicons's Avatar
Default RE: Turbo came in the mail today.
dont go too thick on that gasket. they dont work as well as everyone wants you to think. sure they lower compression, but they also screw up the quench zones in the cylinder head, so it makes detonation easier. so in lowering the CR 1.0, you actually only get about .75 worth of detonation resistence, but you lose the full points worth of torque.
sacicons's Avatar
and a thicker gasket is easier to blow out.
Old 09-10-2005, 10:58 AM
XCM828's Avatar
So should I just get a nice strong head gasket that keeps the same c/r? I'm just worried about blowing the stock head gasket and I want something strong.
Old 09-10-2005, 11:04 AM
fast93civic's Avatar
Speaking of head gaskets, is it totally neccessary to replace when running a turbo? Im talking like 6-7 PSI? Also, are the APR head bolts totaly neccessary? It seems everyone's getting them, I haven't thought about it.
Old 09-10-2005, 12:04 PM
315 Customs's Avatar
for the D series I highly recommend the head bolts because the stockers just arent that strong and I also recommend upgraded the head gasket but running low boost you should be ok as long as you dont have like 150k on your original.
Old 09-10-2005, 12:05 PM
XCM828's Avatar
They're not totally necessary, but it's much better to be proactive than reactive.
Old 09-10-2005, 04:50 PM
damn, I got 142K on my motor so that means a gaskets a must huh? Also, when it comes to those bolts, are we talking about the head studs, or bolts you see on the valve cover?
Old 09-10-2005, 06:04 PM
sacicons's Avatar
the bolts that you have to pull the cover off to get to. that actually hold the head on. and they are bolts stock, and studs aftermarket (ARP) and chances are, your headgasket and bolts are fine, but $150 now while youre already working on your car is better than blowing out a head gasket later and having to wait for them in the mail for a few days, then putting them in. esp if you warp the head from overheating due to the blown gasket.
Old 09-10-2005, 06:11 PM
ok thanks
Old 09-10-2005, 11:01 PM
XCM828's Avatar
So any recommendations on the head gasket?
sfazngiants
09-14-2009 07:48 PM
tha_next_Kobe
09-12-2007 08:12 PM
Overurhead360
06-16-2007 09:48 AM
97_ex
04-21-2007 12:01 AM
Pete
10-07-2005 12:16 AM
Quick Reply: Turbo came in the mail today.
