Turbo Help
Old Apr 9, 2007 | 06:20 PM
  #21
IndyGirlRacer's Avatar
Default RE: Turbo Help
ok well i have a place in mind to do so with that said i will ask him if they will do that for me...they mainly deal with supras...i guess i get to the b the exception....
Old Apr 9, 2007 | 09:53 PM
  #22
SovXietday's Avatar
www.phearable.net
www.j-k-tuning.com
You will need to be OBD1 with a chipped OBD1 ECU. The chip will hold a software that has ECU fuel and timing maps on it that the ECU will read and run. This will allow you to boost the car as well, as boosting a stock car with a stock ecu and stock map sensor will lead to engine failure and a ****load of headaches.
Old Apr 10, 2007 | 09:40 PM
  #23
Well I already have the obd1 ecu, thanks for the websites
Old Apr 10, 2007 | 09:55 PM
  #24
So which one of these would u suggest I get? for only running 6-7 psi.
Old Apr 11, 2007 | 10:45 AM
  #25
SovXietday's Avatar
Have the ECU chipped by someone who knows what they're doing, one of those websites will be fine. I know john (jktuning) he's a cool guy and knows his stuff. Whoever chips the ECU will also put a basemap in it so that you can drive the car to a local tuner so they can tune you. Obviously you don't want to do this until the car is ready to be tuned, as you can't drive around on a basemap.
Old Apr 13, 2007 | 12:42 AM
  #26
does n e one know a good place to do that in the INDIANPOLIS area??
Old Apr 13, 2007 | 01:58 AM
  #27
hondapwr's Avatar
i used to live in indy go to lti and talk to those guys i used to go there they know all the places i forgot most of them but there every where in indy
Old Apr 13, 2007 | 11:53 AM
  #28
ORIGINAL: IndyGirlRacer
I can put you into contact with the guy who did mine if you dont mind mailing it out
Old Apr 19, 2007 | 09:22 AM
  #29
I think i found someone to help me out, but whats his number and junk just in case?
Old Apr 19, 2007 | 09:27 AM
  #30
sway2003's Avatar
what management are you going to run?
soldout712
12
Oct 30, 2006 11:05 PM
forrealb50
Mar 29, 2006 07:57 AM
Jas10hon
Jul 4, 2005 10:35 PM
TrailorParkPimp
Aug 28, 2004 12:21 PM
