turbo or nitrous
Old Nov 1, 2005 | 11:44 PM
  #21
sacicons's Avatar
Default RE: turbo or nitrous
oh, you might as well get one with any turbo setup, but the temperature rise from only 4 or 5 psi isnt enough that an intercooler can get much heat out of it. if the NA intake temp is 100*, and boosted, its around 130-140, then you run 140* air through a not so effective intercooler (cheap ones arent always that great) and youre running 95-105* air through it, its not going to take more than 5-10 degrees out of it. but i personally wouldnt turbo a honda without an intercooler of some sort, even at low boost levels. if nothing else, it makes upgrading easier.
Old Nov 2, 2005 | 09:13 PM
  #22
BallardCivic's Avatar
In my defense, I never said you "should" turbo without an intercooler, but you "could." Guess I should be a little more clear.
Old Nov 2, 2005 | 09:41 PM
  #23
j_fukin_t's Avatar
ORIGINAL: pcupo12
without an intercooler your headgasket is history.
not to mention your turbo will be fried, sounds like he needs to be directed to nitrous, because he's to willing to cheap out on important stuff
Old Nov 3, 2005 | 05:52 PM
  #24
Nail I3unny's Avatar
how would your turbo be fried?
Old Nov 3, 2005 | 08:43 PM
  #25
j_fukin_t's Avatar
ORIGINAL: Nail I3unny
no intercooler = all hot air going through which in turn will make seals go bad poss create shaft play, or even crack the case
Old Nov 3, 2005 | 08:52 PM
  #26
ngoti 8tor's Avatar
Do it right the first time and save yourself any headaches later down the line.
Old Nov 3, 2005 | 08:58 PM
  #27
sacicons's Avatar
yeah, the intercooler has nothing to do with the temp of the turbo. maybe tenths of a degree cooler from the slightly cooler ar going in, but then that would be negated by the warmer air going through the intercooler into the engine bay.
Old Nov 3, 2005 | 10:41 PM
  #28
j_fukin_t's Avatar
yea open mouth insert foot for me huh?? i was thinkin of something else
Mayhem521
Aug 3, 2007 09:31 AM
TeamExodusPres
25
Apr 21, 2007 12:40 PM
thedougler
May 28, 2006 03:33 AM
STFUandrace
May 19, 2006 04:13 PM
CallawayCrazy3
Jul 23, 2005 07:52 AM
