turbo oil
Old Mar 16, 2007 | 07:01 PM
dfdon's Avatar
Default turbo oil
ive got a b16 i am turboing as you ight know and i think i may have to much oil pressure and therefor the turbo is filling up with oil to quickly so i am going to get a restrictor...ne on have this problem or have ne other ideas that i may want to try
Old Mar 16, 2007 | 07:42 PM
t34me's Avatar
Default RE: turbo oil
no, restrictor works quite well
Old Mar 16, 2007 | 07:53 PM
riceburner700's Avatar
that will help. how is your return line?
Old Mar 16, 2007 | 08:44 PM
dfdon's Avatar
what do you mean how is it?
Old Mar 17, 2007 | 11:02 AM
is it nice and gradual back to the oil pan or is there any sharp tight bends in it? thats how mine was at first because of how low the turbo sat. it would blow smoke while cruising around an a sh*tload while under wot. fixed it with a different return and a different manifold. it barely smokes while under full boost, nothing that isnt normal from running a little rich
Old Mar 17, 2007 | 02:42 PM
dfdon's Avatar
its pretty good i know it all is going back to the pan via gravity so i cut as much as possible to make it as easy as possible ill go snap some shots put them up you can tell me what u think
Old Mar 17, 2007 | 10:36 PM
next i would try that oil restrictor before it enters the turbo
Seafoamgreencivic
34
Aug 12, 2008 09:30 AM
oilltd
Jun 10, 2008 04:06 PM
Vadagar
May 26, 2006 12:51 PM
DotComx
Dec 24, 2005 04:06 PM
