TURBO XS TURBOCHARGER
Old Aug 2, 2005 | 03:01 AM
Pete's Avatar
Default TURBO XS TURBOCHARGER
Ok here are the specs on the turbo i was looking at. Im pretty sure its not the BEST turbo.....but will it be good enough for runnin 6PSI for daily driving?
T3/T4 TURBO INFO ( D16 SERIES )
3" INLET DIAMETER
2" OUTLET
WET FLOATING BEARING
1/8 NPT OIL INLET
T3 / T4 FOOTPRINT OK !!
SPECS:
.50 A/R / .63 HOT SIDE
STAGE III WHEEL
TURBONETICS CAST HOUSING
BALANCED AND BLUEPRINTED AND COMPRESSION TESTED
Old Aug 2, 2005 | 10:16 PM
Pete's Avatar
Default RE: TURBO XS TURBOCHARGER
cmon turbo gurus.......where ya @
Old Aug 2, 2005 | 11:57 PM
Marty's Avatar
May be ok depending on the exhaust size and so on.It will have lag with out a doubt a .50 A/R - .63 is a pretty big turbo for a daily driver non built sohc but let me tell you this,it will spool hard at around 4000 to 4300rpm and pull crazy untill redline even at 6psi
Old Aug 3, 2005 | 12:36 AM
LEVIII's Avatar
Do you know what the CFM on it is? That is one of the most important things about a turbo.
Also just an FYI, TurboXS and XS power or XS turbo are totally different compainies.
bubble
Oct 4, 2006 05:02 PM
StifflersMom
26
Aug 21, 2005 03:37 PM
Quacan
Jul 23, 2005 07:35 AM
claudeboi
Apr 7, 2005 02:12 AM
Super Mario
Dec 6, 2004 12:13 PM
