Turbo'd D16, having cooling problems, need help....
Old Sep 23, 2007 | 01:51 PM
civicninja98's Avatar
Default RE: Turbo'd D16, having cooling problems, need help....
ok cool, so where can i get some of these arp's? And does anyone have a recommendation on a certain type or brand of headgasket I should get?
Old Sep 23, 2007 | 02:10 PM
kokasian's Avatar
Cometec makes just about the best head gasket you can buy, but an OEM one would work in your application as well. For head studs, try http://autosportcity.com/default.aspx
Old Sep 23, 2007 | 02:12 PM
K cool. I will go ahead and get all this stuff and try to get it put in this week if i can. Gettin married in 2 weeks, so time is kinda tight. Thanks for the help. If this doesn't work, I'll be back and we'll see if we can come up with something else.
Old Sep 23, 2007 | 02:46 PM
StifflersMom's Avatar
Cat Fuсker
just make sure you clean the mating surfaces really well and if you're doing the headgasket, might as well do the water pump and timing belt if they're not recent.
Old Sep 24, 2007 | 12:29 PM
riceburner700's Avatar
i would also check to see if the head isnt warped and is still flat. copper coat the headgasket before you install it to get a little extra sealing
Old Sep 28, 2007 | 03:55 PM
Ok, thanks for the help. I am waiting for my parts to arrive. If this doesn't fix it, then what else do you think could be wrong?
Old Oct 1, 2007 | 02:03 PM
bcrichguitars's Avatar
I'm having the same problem.
I want to buy all my internals at once and them professionally installed, should I wait until then and just get some arp headstuds and a new head gasket? Why would I need a new headgasket, wouldn't I know if it was blown by overheating and oil and coolant miscolor?
How much would a shop charge to change a headgasket?
xpdude
Aug 16, 2009 10:26 AM
civicninja98
Sep 23, 2007 01:27 PM
crsoardREX
Aug 7, 2007 09:35 AM
classiccarsrule85
Jul 29, 2007 06:39 AM
markwilson
ED-EF Swaps
Apr 6, 2007 10:59 AM
