What kind of turbo
Old Aug 1, 2006 | 06:29 PM
BillyB98's Avatar
Default What kind of turbo
If i want to get a turbo for my car and dont want to spend a large lump of cash what should i get. Im talking if i went to a salvage yard or something what should i look for. Eclipse, talon, etc? and what would i all be able to snag off them?
Old Aug 1, 2006 | 06:31 PM
pWnEdU's Avatar
Default RE: What kind of turbo
www.turbod16.com
Old Aug 6, 2006 | 12:28 PM
MY99SI's Avatar
i woulnt buy a junkyard turbo.. but thats me.. you would never know how the car was maintained and how it was driven. spend the money and get a new or reman. turbo.
Old Aug 6, 2006 | 12:37 PM
Fiirkan's Avatar
Well if you did go to a scrapyard and halled a turbo off of a car, check to see if there is much shaft play, and if you can get it cheep enough, but still want to ensure that it will work, you can get turbo rebuild kits for about $100 off the net
Old Aug 6, 2006 | 04:51 PM
10isAce's Avatar
I have a saab 900 (mid 80's) t3 turbo junk yard style in my 95 civic for like a $100. I'd do it again. The junk yard one lasted for 1 full year 15k miles. I would assume that would be typical, b/c a lot of the junkyard turbos have 100k+ miles on them, so you may get 10k to 50k miles or luck out and it lasts for 10 years. who knows?
Just make sure you are getting the right a/r you want and check for shaft play (like Fiirkan said) and oil residue coming out the seams. Do some research. I have .48 a/r turbine and .42 a/r compressor. I like the response around 3000 rpm full boast, but I'm researching for an even quicker spool up. I want something that is fast from a stop and also can punch it at freeway speeds.
If I were to drag I would go with a bigger a/r, but not for street use.
Stick with oil cooled only, it's easier, just my opinion.
Good luck!
Old Aug 6, 2006 | 05:19 PM
Pete's Avatar
Oil cooled IS Much easier. Junk yard turbos are good, but it depends. If ur putting a custom kit together and know what youre doing, its a good idea, but the turbine is the main part of the system, and you shouldnt cheap out on it, considering a good garrett can be found on ebay for 250 or so.
Old Aug 7, 2006 | 12:15 AM
Fiirkan's Avatar
most of the good turbos that i have found on eBay were like $500 just for the turbo and BOV, i couldn't find any inexpensive ones
Chojnacko11
Jun 1, 2011 10:19 PM
administrator
Sep 2, 2007 04:14 PM
gunmetal
Aug 17, 2005 11:33 PM
Cypress96CivicLX
Dec 21, 2004 11:44 PM
civicvtecpwr
Jun 21, 2004 07:39 AM
