04 civic lower tie bar install?
Old Oct 31, 2007 | 10:51 PM
benjammy007's Avatar
Default 04 civic lower tie bar install?
How do you install a lower tie bar on a 04 civic ex? do you have to jack up the car? its double wish bone and i dont know which bolt to remove... please help
Old Nov 1, 2007 | 05:46 AM
Nerosync's Avatar
Default RE: 04 civic lower tie bar install?
If it is like my 05 and it should be as those two years not very far apart, you will need to jack the car up until both tires are off the ground. (At least the instructions with mine said too). Once the rear of the car is off the ground then remove the two inner lower control arm bolts(these can be a pain in the *** sometimes to remove) Once you have the bolts out place the tiebar up there and bolt it into the holes where you just took the bolts out. The tie bar should have come with longer bolts to allow this. Here are pics of what my 05 looks like with the new sway and tie bar combo to give you an idea. The two bolts on either side of the word Progress are what I am referring too.
[IMG]local://upfiles/26094/5E67691F93E2489CAC3A30B15DDB9259.jpg[/IMG]
Old Nov 1, 2007 | 07:02 AM
oh sweet yours look cool. I cant wait until I put mines on tonight after work
Old Nov 2, 2007 | 06:20 PM
ok how do you get the bolt to align once you get it off... mines shifted to the right and i cant get hte bolt back in!!
Old Nov 2, 2007 | 07:48 PM
Nerosync's Avatar
I used a 2nd jack under the control arm and just barely lifted it enough that I could stick a screwdriver in the hole to line it up then it would stay there allowing me to put the bolt in.
FlipHKD720
Aug 12, 2006 03:28 PM
D16z6
May 22, 2006 09:24 AM
deadphishy
Feb 21, 2006 07:31 PM
Super Mario
Dec 14, 2005 07:08 PM
Fibercation.com
Nov 28, 2005 11:32 AM
