22mm sway bar, should I buy *pic*
Old Nov 8, 2007 | 06:27 PM
mxs's Avatar
mxs
Default RE: 22mm sway bar, should I buy *pic*
ORIGINAL: mill$civic
he said that he dosent have extended LCA bolts, he used OEM ones, will this work?.
I don't remember how much longer than stock the replacement bolts were. If it worked for him it should work for you I guess
One last thing, its just the bar that bolts on to the subframe, then the sway bar gets put onto that, there is no metal backing that goes on the other side of the subframe, is that right? Just the brace gets bolted on to the frame, and the sway bar to that and Im good?
You will need to drill a couple of holes in your subframe to mount the brace.
I'd replace the bushings: http://www.energysuspensionparts.com...20Bushings.asp
Old Nov 8, 2007 | 06:42 PM
mill$civic's Avatar
Ok thanks, Ya he said that he has everything from when it was bolted onto his car so it should bolt right up..I hope... But I got all winter so I'll get the replacement bushings. Thanks.
enigma34
Feb 23, 2010 07:33 PM
VSTmike
Suspension, Brakes, Wheels & Tires
May 23, 2008 04:32 PM
snosurfa7
Apr 8, 2008 09:15 AM
mill$civic
14
Dec 24, 2007 06:31 AM
D16z6
May 22, 2006 09:24 AM
