ABS problem
Old Oct 2, 2005 | 08:11 PM
rzimmer11's Avatar
Default ABS problem
94 Civic EX....GSR motor....Im getting an ABS light on which isn't turning off. Also when braking in low gears the brakes pulsate like in a brake locking situation; at that time I can hear a clicking coming from underneath the passenger dash which I'm assuming is a relay of some sort. Any ideas of to what could be causing this problem? Thanks
Old Oct 2, 2005 | 10:08 PM
AgentofDarkness's Avatar
Default RE: ABS problem
There should be a wheel with a bunch of teeth on it near the hub. Check to see if the sensor that goes next to the wheel w/teeth is connected and also check taht there aren't any broken teeth.
Old Oct 2, 2005 | 10:20 PM
chaseman1978's Avatar
normally if the light is on, then the computer has stored a trouble code...
dstroman
Mar 14, 2012 08:36 PM
bfodle
Jul 20, 2011 09:57 AM
martyb555
Mar 12, 2009 07:32 PM
Chirp3rd
May 12, 2008 03:24 PM
kukanator1
Aug 23, 2007 05:05 PM
