Anti-roll bars 92-96 hatch
Old Aug 13, 2007 | 06:04 AM
OliPowell's Avatar
Default Anti-roll bars 92-96 hatch
Is there a kit for putting anti roll bars on a eg hatch. I know some already have them as standard but mine doesn't even have the mounts. Is this normal because I checked some others and all of them have the mounts but only some have the bars installed? Iv'e had a look around and I can't find any answers (but maybe im blind). Is there a way around it?I canget some arms with the mounts from the local scrappy but ive just replaced all the bushings & don't really want to go down that route.Can you get adapters or is there another way to reduce massive amounts of bodyroll? (shocks & springs have beenrecently replaced)
Thanks
Old Aug 13, 2007 | 06:51 AM
riceburner700's Avatar
Default RE: Anti-roll bars 92-96 hatch
strut tower bars will help. when you put sway bars on a car that didnt come with them you wil need the control arms off a car that did or aftermarket ones
Old Aug 13, 2007 | 07:04 AM
OliPowell's Avatar
I have a front upper brace, helped abit but not really enough. Would I notice a bigger differance if i got the anti rollbars on the front or rear (i was planning rear unless someone says otherwise.)? I found this http://grassrootsmotorsports.com/new...a-rear-bar.phpbut those brackets look a bit on the flimsy side.
Old Aug 13, 2007 | 01:01 PM
civicexracer's Avatar
for a rear swaybar, u already have the holes in the subframe to mount the d-brackets too but they need to be slightly modified(a few tack welded nuts on the inside of the subframe that need to be broken off). u do not have the endlink holes on ur lower control arms tho. that means u'll need to either buy LCA's from another honda that has the holes, or buy after market LCA's. for a little over $100, might as well buy new aftermarket ones, look good, lighter, and new bushings. u will also need a subframe brace of somesort. i have the Beaks subframe kit with a 22mm rear swaybar on my car and its holding up great.
Darklisk
Jun 15, 2010 05:31 PM
slivergun
Apr 28, 2007 01:30 PM
mybrokenblinker
18
Mar 19, 2007 02:34 AM
Savatage
14
Nov 25, 2006 12:35 PM
civicstealth
May 8, 2006 08:20 PM
