BBS Wheels.. Thoughts?
Old Sep 19, 2010 | 09:21 AM
^^ what do you mean about the hub thing? I did not get extended wheel studs.
Old Sep 19, 2010 | 09:40 AM
MaximusFunk's Avatar
When i tried to put them on the car, the studs barely broke the surface so as I couldnt even get one turn of the lug nut onto it. the back of the wheel is like the equivalent of a wheel spacer, but it is part of the wheel. Wish i had yours :P
Old Sep 19, 2010 | 09:47 AM
I had the same issue in the beginning. Did you try pushing on the wheel while pushing slightly up as well, I did that and it felt like the wheel seated onto the hub a little better allowing me to get the lugs on. It could have been easier though.
The way it was worded before, it sounded like the hubs dont match up 100% and may cause issues in the future.
Old Sep 19, 2010 | 09:54 AM
I will give it another try later, I hope you are right. Wheels might be diff though, cause I just noticed that yours are 15'' and mine are 14''. Mine came off of an 88 bmw e-30
I like your honda center cap better than the BBS one, Ill prolly look for some tonight.
Old Sep 19, 2010 | 10:19 AM
I have a set from the CRX wheels I bought, but the honda caps have to be slightly grinded down to fit properly, or the plastic tabs on the inside will crack. I'll see if I can get a pic of what I am talking about. The guy before me just shoved them in there and cracked them a little.
Yours are 14's? I am interested on seeing what is engraved around the hub on yours. I will snap a pic of mine in a minute.
Old Sep 19, 2010 | 10:25 AM
Kenny-g's Avatar
I'm Spock Dammit!!!!!
Those wheels are pure win! I like em and Max.Funk, what color is her car again? green or something right? Idk the silver should look nice tho!
Old Sep 25, 2010 | 11:48 AM
I cant read the numbers cause the paint is pretty thick, but they do have BBS stamped on them. Thats just the primer, Im gonna use wheel paint. I have been too lazy to continue with the project the past week.
MaximusFunk
Jan 23, 2011 04:03 PM
MaximusFunk
Aug 25, 2010 06:07 AM
brajj
Mar 16, 2010 09:02 AM
Nevadanut
Oct 6, 2006 07:45 AM
andryuha
Jan 30, 2005 03:36 PM
